Bah im in a deep problem lol.. i changed the keyboard lock and all fine now i turned on power of the n70 and the keyboard lock doesnt match what can i do? I cant go to nokia because i dont have the buyer prof i buyit in ebay ;||| what can i do??? ;''(??
Another Keylocked
You mean you changed the lock code? Go to www.symbian-toys.com and install the app called UnlockMe. If you can't install anything... that's it, you need to take your phone to a service.
but how can i go to the service if i dont have the prof that i buy it? dont i have any other solucion?
Now my n70 dont turn on ... -.- what is happening.. is like dead lol...
When i try to charge it it becomes red ..then one minute after green...then i try to turn it on and nothingggg ;''(
Then hard format your little bastard.
We need to do a sticky about changing the code lock lol
Then what i do to change the code lock?
Hard format and then? i tryied the 12345 and nothing happen ... how i hard format it?
Format info:
http://www.allaboutsymbian.com/forum//forum/thread/17507/
It won't remove your lock code, though.
