Wifi Wlan no gateway reply
1 replies · 8,653 views · Started 10 January 2007
Well I found out that nothing is wrong with my N80 it works perfectly.
I was able to log into a gateway but not my gateway at home. Somehow not sure I was able to long in there but not at home.
I've done everything from change names, of router, reseting it, and every time no gateway reply. My computer, wirelessly, still logs in just fine but sigh :dontknow:.
Anyway I've reset my Router and STILL no gateway reply. Funny thing is it, at one point, was able to let me log in without a problem. Disabled Security so that at least I know it ain't that. So some one any one tell me what to do. Note I'm about to re-update firmware on router again.
And I can't update my n80 I guess it's updated all the way. Oh and it's set on DHCP. A Linksys WRT54G v5. Oh and Windows XP 64bit.
Fixed it...The 2nd computer was messing everything up. Haft to set everything to WPA and once you do that it stays put.:icon14: :redface:
