Voice Tag/Dialing
3 replies · 1,928 views · Started 10 January 2007
Hello all,
Does anyone know of a software that will record my own voice for tagging/dialing?
The computer voice on N80 can't pronounce the name correctly so it will not recognize my contact name when I try to voice dial.
May b I sho ulD sp Eak ly ke A com PU der 😮 🙄
Thanks in advance.
found this from another post, thought it might help.....Pete 😉
"I've also found now that if you fill in the nickname part of your contact with something more appropriate for voice dialling then if you say this nickname the intelligent voice dialling will regonise that and hopefully dial you the right number."
peter7769 wrote:found this from another post, thought it might help.....Pete 😉
off to try this out... the voicedialling on v4 is terrible... or maybe its an accent thing...
