ScreenTaker is a freeware utility which gives you the possibility to take screenshots on your Nokia Smartphone any time using the defined key combination. Screenshot with the name you assign to it will be saved in your images folder.
ScreenTaker instructions:
- After the program start you can press Hide button to send the application to background and then when you want to take screenshot press 'ABC + Menu key' to make it.
- Program allows you to define an image name after taking screenshot.
- Taken images are saved directly to your Images folder, that allows you to view taken screenshots and send them by MMS, Infrared or Bluetooth later with standard 'Images' application.
- All the images are saved in jpeg format, so these highly compressed images won't take much space on your device. Also you can send them and view on your PC without converting
- Program uses 16Kb of disk space only or 6Kb only when compressed with SmartCompress application.
More info and program download is available here:
http://www.symbianware.com/product.php?id=screentaker60&lang=en&pl=all&s=0
[quote="Hera"]ScreenTaker is a freeware utility which gives you the possibility to take screenshots on your Nokia Smartphone any time using the defined key combination. Screenshot with the name you assign to it will be saved in your images folder.
http://www.symbianware.com/product.php?id=screentaker60&lang=en&pl=all&s=0[/quote]
Just what I needed the other day :roll:
Thanks for the information 😃
Thanks for info, been looking for app like this for a long time, for free that is 😃
Dont have so much use of this to buy one. And I dont own a SeleQ
Thanks for sharing!! That's a useful appl
thanks. there should be more like you in this world!!! 😃
more dangerous the 7650 will be with this appss .......... spies 😃 😃
Excellent app and image quality. Now I can remove seleq, go back to using Handyfile and save 100+ k on my phone.
Stezos
Thank you very much for the app!!
[quote="Manowar"]Thank you very much for the app!![/quote]
hey, hey, i know you're particularly looking for an app like this. 😃
