Podcasts for N73 ?
7 replies · 3,764 views · Started 12 January 2007
Is there an easy way to get free Podcasts on the N73?
Do one have to use iTunes and convert with Super etc or does N73 support "Podcast format" without conversion..
The N73 isn't really suited for podcasts though. It doesn't support bookmarking, and whilst you can pause tracks, switching off the phone, and it doesn't resume at the same point. Even my venerable SE W550 could get that right.
clovis_ll wrote:there is... its called nokia podcasting, here you go
Superb dude, but this link is for N80. Will the N73 work anyways?
Yes it will work fine on the N73 too. Try nokia.com/podcasting for more generic stuff.
I can't get no podcast to work on my N73, no audio og videopodcasts!
I get this error when trying to start a audio mp3podcast:
"HTTP header returned with error"
And this when trying to play a video podcast:
"Content cannot be played on the device"
I hear that N73 don't support videocast, but are the no 3.party podcast software that work on symbian and N73 etc? :con?
Morty
MortyOslo wrote:I can't get no podcast to work on my N73, no audio og videopodcasts!
Sorry my bad! I used the wrong access point connection in settings.
Now things are downloading :icon14:
Morty
Hi
My 3UK N73 has Mobilcast on it...works great, visit melodeo.com and check out the "mobile" link....think it only plays Audio podcasts. Did you find a vidoe podcast app?
