pleeeeeeeeeeeeeeeeease help N80IE, NAT & VoIP
2 replies · 2,245 views · Started 12 January 2007
can someone confirm that N80IE with FWD voip will work behind NAT
after I finally upgraded to n80ie only for that reason...I tried all possible configuration and I cant get the phone to register with FWD.....so I am assuming that n80ie does not support voip behind NAT
plzzzzzzzzzzzzzzz confirm that so I stop trying
Muheeb
Depends on a few things...
Firstly some routers work better than others straight out of the box.
Secondly most of the rest will work fine if you can get things like the STUN settings configured... however they're not available for editing from the user interface.
If Gizmo works on your phone then it's the hidden STUN and NAT settings you need to play with, if not then you might need a new router.
