does any body know how to delete a call made or received or any message in or out from the log, not the folder of calls or messages, fromn the log where all activity of the phone is registered ??
log in N80
I'm not exactly sure what you are asking, but in the Log program you should be able to select the entry and press C. To be completely cover up your change you could reset the counters too.
satt wrote:does any body know how to delete a call made or received or any message in or out from the log, not the folder of calls or messages, fromn the log where all activity of the phone is registered ??
Sounds like you are up to no good 😉
but it just work in the particular folder where is the call or the message, but there is another log, where just register if the call was in or out and if the message was in or out and where it also register the lan conecctions there just can erase all, not only those that i want to delete...
