I'm trying to work out how to forward a contacts number when sending an SMS message, as it doesn't seem to be in the N80's options menu, when writing a message.
I would be grateful if someone could help.
If you go into your contacts, scroll to contact you wish to send, select options, send, via text message - you can then send that contact's details to a chosen recipient. Hope that helps.
BHLC
yeah, can be a bit flaky is you try to send ALL DETAILS to a non nokia tho it seems.
kontraband wrote:yeah, can be a bit flaky is you try to send ALL DETAILS to a non nokia tho it seems.
Their problem not yours 😊
apisto wrote:Their problem not yours 😊
