n80 messaging probs
5 replies · 2,756 views · Started 13 January 2007
hi
for some reason some of my text messages when sent go to drafts folder.
Its random so sometimes it does it and other the message sends fine.
does anyone know how to fix this as its annoying thinking you have sent a text when you havent
thanks
1. try the latest firmware upgrade via nokia updater!
2. from the nokia site download and install sms accelerator, it might be a time issue as to why they store themselves, it works a treat
wayne
tanov wrote:1. try the latest firmware upgrade via nokia updater!
wayne
yeah thats a valid point... it may be getting delayed in sending and moving to drafts.
robnash wrote:Don't they get stored in Outbox if they're not sent straight away?
yeah, normally ... as deferred or sending.
BUT, this didnt sound like a normal case.
You could try turning off 'save sent messages' turn off and then restart and turn it back on...
or just dont save you sent messages??
