After hours and hours of frustration, finally I got a solution to this problem.
Just to re-cap, the issue is to sync the M600i with exchange server. The error message that you get - identified in the first posting in this thread - identifies a problem with your exchange server settings.
If you set the verbose log on your phone, try to sync using the Active Sync programme, you get an error code 0x7370D02.
an explanation of this error code can be found at - sorry I cant post the web address - I am too young a forum member
(thanks trifin - from the startcom forum)
So here is what it says!
The sync error is a type 403 and this is the solution:-
This error can be caused by an incorrect setting in the Exchange Server. Please contact your IT staff to confirm the following Exchange Server settings:
A. First, contact your IT staff to confirm the Exchange server uses "Integrated Windows Login" (see Microsoft documentation: - sorry wont accept the url!!!!
B. Also, please confirm with your IT staff that your account is enabled for ActiveSync.
C. Next, contact your IT staff to confirm that device security settings on the server allow access to devices that do not fully support password settings. This option is available in:
Exchange System Manager > Global Settings > Mobile Services > Device Security
If this checkbox was unchecked, you will get a 403 error with RoadSync, although a Win Mobile device would still sync properly.
Important:
In the Device Security Settings, if the first option "Enforce password on device" is unchecked, the settings below it are not applicable and won't effect RoadSync. If the "Allow access to devices..." box is unchecked and then checked, it will take approximately 15 minutes for the system to update and for RoadSync to begin to sync properly.
I checked the box, waited 15 mins and BINGO!!!! it worked!!!!!
YIPEEEEEE!!!!!
One side effect is that the 133 emails that sync'd have now cost me a fortune on vodafones GB ripoff tariff!
I recommend you uncheck the "push email" box on your phone and chose "manual" - to save you some money!
I cant tell you how happy I am!😊 :icon14: :icon14: :icon14:
