I have loads of images for apps and tomtom poi's etc (not to mention a few 'sensitive' pics and vids 😉 ) and they all show up in the gallery....how do you stop that?
Thanks.
Thanks.
Sadly, you can't.
Best way to protect others from your "sensitive" pics (😉 ) is to only view them via albums.
It's a feature 🙄 :con?
Remove the files from the Images gallery(those files which u don't want pple to see...) and move them to folders like Others or create a folder for them.
or try to change the attribute of the tomtom's folder.. set it to hidden..
karthikeyan10 wrote:Remove the files from the Images gallery(those files which u don't want pple to see...) and move them to folders like Others or create a folder for them.
This won't work as the Gallery function scans the entire phone and displays all images found, regardless of location or folder name 😞
wapski wrote:or try to change the attribute of the tomtom's folder.. set it to hidden..
You know, I read that and thought "Bloody hell, of course !" but I tried it and it doesn't seem to work 100% What I got was a load of broken thumbnails :con?
I'll investigate further.
Get a 3rd party file browswer that allows you to change the attributes. Can't think of the name of the one I've used before, but it is out there. Y-something or other. Works fine, and all your pr0n is safe from prying eyes (which is presumably what these "sensitive" pictures are...
neuro2006 wrote:Get a 3rd party file browswer that allows you to change the attributes. Can't think of the name of the one I've used before, but it is out there. Y-something or other. Works fine, and all your pr0n is safe from prying eyes (which is presumably what these "sensitive" pictures are...😉
Can't seem to get this to work for the TomTom images though 😞
use y-browser
lector wrote:use y-browser
I am ! 😡
Browse the memory card on the PC (via a USB key reader), remove the _PALbtn folders (these store the thumbnails).
Then move the files you want to "hide" into a hidden folder.
Use something like Resco PhotoViewer to browse for the hidden folders. Visible in Resco, but not visible in the Gallery.
