Hi All
All the info I have seen so far for the standard Internet Email client for the p800 says it supports IMAP4, POP3 and SMTP
Does this support also include SSL / TLS support for IMAP4 / POP3 / SMTP as well??
I have not seen anything which mentions this explicitly so far and have not been able to play with a p800 to find out for myself 😞
Considering SSL / TLS (and cert management) is supported by the browser - I guess it should be possible for the email client as well.
I think that series 60 does support this capability - so hopefully it should be something supported by the p800
If the p800 does not, I think I may give up waiting and go get a series 60 based device instead :-?
royster
I sure hope so!
(If not, it ought to be trivial to
set up an SSL tunnel, though.)
[quote="lcs"]I sure hope so!
set up an SSL tunnel, though.)[/quote]
Does this mean there will be an SSH client for the phone?
there d better be one, as this is one of the main uses i plan for the phone, remote admnister a bunch of servers
There is already a version of Putty (SSH client) ported to the P800. Yes, the email client supports secure connections, however, I'm having trouble getting it working at the moment myself.
Tristero wrote:There is already a version of Putty (SSH client) ported to the P800. Yes, the email client supports secure connections, however, I'm having trouble getting it working at the moment myself.
Where can I download a copy for testing?
Regards
Bn
I can assure that it does. I have the opposite problem: my company uses MS exchange and that does not support TLS. As a result... No email possible from my P800! I am now trying a separate program ProfiMail which does not use TLS and that works ... sort of.
So you're lucky, I'm not
