I hv Nokia 6260.
whenever i receive any msg thru bluetooth or otherwise it saves in the phone memory.
I don't know how to change the phone memory to MMC Memory so that i can receive the msg in MMC memory
For the above purpose there is option [B][B]MESSAGING>OPTION>SETTINGS>OTHER>Memory in use [/B]in nokia 6600 [/B]But the memory in use does not appear in my phone.
Can any body help me out
i don't think this is an usual problem, so u better try another memory card and see if the same problem occurs, cuz it might be because of the card...or mabe just formating the card could help..
The "Memory in use" setting is missing from both the 6260 and the 3230 models. It simply isn't there.
It wasn't there on the original N-Gage and N-Gage QD, either, but someone hacked together an app that allowed you to do it anyway. As far as I know, that app works - mostly (use at your own risk) - also on the 6260 and 3230.
Search for "msdrivee" or "mvsdrivee" (or both) and you should find it.
