Is there better fonts than the originals for N70 ?
F O N T S
Yes.
Download EasyGDRCreator.
Because it was written in Thai language, none of the menus appear correctly!
But there's lots of tutorials to use it.
http://crazylittleworld.com/2006/03/making-the-most-out-of-nokia-n70-part-3/
or here
http://www.symbian-freak.com/tunning/fontquide/font.htm
It's a bit fiddly changing between fonts becasue you have to delete/rename the original font set each time but it's ok once you're there.
Takes a bit of trial and error to get a font with which all characters will work.
Sometimes you pick one and things like currency signs or brackets are viewable.
See my screen shots for text examples.
Chris
Thanx Chris for your detailed description. I do know how to use the mentioned software to create fonts for symbian phones. But every new font that I created was not as good as original one. Anyway, I impressed by your theme ! Is it copyrighted or freeware? please say me its name ....
Hi Parva,
Like I said, it takes a bit to get one right.
My theme is not copyrighted, it's free from zedge.com.
I can post it here if you want it.
Chris
I will appreciate if you upload it.
Hi Parva, sorry for the delay.
This is the SIS file for Just a Blue Dot.
Cheers,
Chris
Thanks.
