When i open the gallery it displays the message "Opening files" for a while and then close to the menu .... and when i run more than one thing in the back ground for example the contacts and the log when i press the menu key to switch between opened files and click "c" to exit one of them it doesn't exit and when i switch to it , it is not working and the calender is not working it just freez... i have tried removing the memory card i've tried to restore it to factory sittings ... i even tried formating .. all that didn't solve this problem ... please help i don't know what to do.
6600 problem please help
toulan wrote:When i open the gallery it displays the message "Opening files" for a while and then close to the menu .... and when i run more than one thing in the back ground for example the contacts and the log when i press the menu key to switch between opened files and click "c" to exit one of them it doesn't exit and when i switch to it , it is not working and the calender is not working it just freez... i have tried removing the memory card i've tried to restore it to factory sittings ... i even tried formating .. all that didn't solve this problem ... please help i don't know what to do.
Hi freind format ur phone wid *3 and call send (green)
and get away frm all problem
But all ur contacts will also vanish so first copy it on sim
I have done that already 2 times but still the same problem... the gallery , calender , bluetooth and even when i capture a photo with the cam it says "Temporary over-load. Continue." 😞
Then, go to a Nokia Service.
Yep i've gone to nokia service center and it was a hardware problem i was told that something wrong with the bluetooth hardware and it is fixed now, Thanks you guys for help 😊 i hope that this be useful for someone
