hello.
i just updated my N80 to N80ie and do I still need to load SMS Accelerator from Nokia?
not sure if it's already included in the IE.... if I load it again, will it mess anything up?
thanks
hello.
thanks
eggyacid wrote:not sure if it's already included in the IE.... if I load it again, will it mess anything up?
If it is still taking ages for SMSs to send I would certainly try the program. I would have thought Nokia anticipated it's use on IE phones.
Don't think it's needed. The application isn't included in the software section on the downloads page for the N80IE which would suggest to me that it's not needed
If you check the application manager, it's not there. But, in my case, the SMS are sent fast, so no need to install it.
my takes about 25 seconds to send a SMS.
don't remember how long it used to take... but is this normal?
or should I try to apply the SMS Accelerator?
SMS Accelerator is built into N80IE firmware so no need to install it
eggyacid wrote:my takes about 25 seconds to send a SMS.
you can try moving your sms's to your memory card or vice versa. This may speed it up for you.
