Power Switch Problem
1 replies · 1,257 views · Started 21 January 2007
hey all,
I have a bit of problem in my 3230.
this is it :
when I sometimes press the power button to change the profile, nothing happens but after 10 or 20 minutes
it is functioning well, same happens when i switch it off too(when you press nothing happens.). Is it a problem with the switch or circuit , or is it a software error???
after switching on the phone is normal, this does not happen alwayz, please help me on this matter
because there is no nokia care center in my area ......
thanks....
It looks like your button is not well soldered (HW issue). If you think you can solve this problem by yourself... then do it. I would recommend you to go to a service, though.
