any body has his hands on the new Nokia N95.
I need to know if N95 has the same SIP client as the N80IE or will it support VoIP behind NAT and Stun servers.
thanks
thanks
The N80 already supports STUN and other methods of NAT traversal, however these settings are not exposed by the user interface (this is apparently a concious descision by Nokia to avoid confusing the casual user). I think it would be highly unlikely that they will remove these hidden settings from the N95 version, however I also doubt if they'll add them to the user interface anytime soon.
We're still waiting for Nokia to release their SIP Profile SDK which will allow us to create SIP configuration files that can take advantage of the NAT traversal methods, until then we're a bit stuck.
