K heres the problem i installed a couple themes, and saved them to the memory card. When i try to apply these themes some of them are missing. Also in application mgr i cant find the installed themes, only if i view installed logs. What is going on, where can i locate the installed themes?? And where i can view them on the memory card?? Thakyou
N73 Application Installer PROBLEM
It happens some times... Install again the same themes. Maybe it works.
Ok managed to solve the problem by deleting themes from the memory card at: I:\private\import\10207114
What folder do themes installed on the phone appear under?
Also i cant install those themes that i deleted from the memory card again. It goes through the process and right after it reached 100% an ERROR msg reading "unable to install!". NOW WHAT could it b, thankyou?
