I have recentely purchased N73. It's a great phone. My only concern is there any way to increase the font size. I dont want to wear my eye glasses for that. In my previous Nokia (Forgetting the NO) i could easily see the telephone numbers. It was easy to write a sms also as the font size was quite big.
Any suggestions will be highly appreciated. I dont want to sell off this lovely phone for font size only...
N73 Font size?
I understand your concern... The only way is with the use of a more high contrast and clean theme, like igbase2 or turquoise - both free and easy to find on net. For me, also a good one is N95 violet theme, because the letters are white, over dark image... not bad.
Thanks for your tip. I will definitely look around the themes as mentioned by you. However I have changed the themes which are available in the phone. It does make a lot of difference.
However still some more suggestions from other members are most welcome.....
I got the website IGBASE for themes. It’s a dump question. Hope I will get the answer. I have downloaded the concerned theme on my desktop. The question is now how to transfer it via blue tooth or the cable provided by the Nokia73 to the phone.
Is it possible I can get the step wise info as i have never copied the things from the computer to the phone.
Your best bet is to install PC Suite. That way, once you have connected the USB cable (and the phone has been recognised) you can double click the .sis file and it will install.
Thanks Rafe. I installed PC suite and the problem is solved. Its a great forum.
