How to delete an Application????
7 replies · 3,195 views · Started 22 January 2007
I have downloaded an Application and sent it to my phone via bloototh.
No problem with that, as I've done with a lot of apps.
However this one, could not be instaled and is not leting me delete it!!!!!!:con?
When browsing the Application manager, I can see this app in there but have no options to delete it.
This app is a .sis file, so it should be straight forward.
I couldn't find this app, when browsing via PC.
Any clues?
TIA
If the app is in your menu, under Internet, or My Own depending on your version, select it and press C.
Otherwise a memory reset sounds best. Sorry I can't be much more use.
This is the thing,
The application is not on my menu, nor under internet, it came via blootooth from my pc(I sent it), but it couldn't be installed.
I'm asking that, as everytime I start my phone, a message comes up saying:
Installing.............
Untrusted software found on memory card. To install go to applications manager.
When I go to Applications manager I can see it in there
The application calls a0000bf5.sis
Any clues:con?
TIA
You could try and find the original SIS file and delete that. It should be somewhere on the memory card by the sounds of it.
kormisr wrote:This is the thing,
Any clues:con?
TIA
Try install that file, because on first screen you see what is the real name of that program. That way, is possible to try again the installation from the original file, and after that remove.
In the application manager it should let you choose to install programs without a certificate or something like that. It should install when u allow them to install.
Any clues:con?
TIA
Put your phone in Mass Storage mode and delete it that way!!! I had do do it it works. Make sure your set up to view hidden and system files. Hope it helps!!!
Hey everyone that tried to help me, THANK YOU.
sorry about the delay on the reply.
Everything is sorted now.
I forgot a simple procedure.
Just loaded the memory card on the PC via a pen drive and treated as a normal removable drive.
It wouldn't work via Nokia application
Thanks again
Case closed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:icon14:
