help,
my nokia n80 says offline
help,
click the power button and scroll to general profile.
when i try to put it on general profile it says unable to change profile
can you turn the phone off... check sim is seated properly and then restart?
done that too m8
ok... how about...
1. removing the sim and turning phone on without it in... check status and then turn off re insert sim and check
2. trying a full phone reset.. although you'll loose some saved data so need to back up.
3. firmware update from NSU.
BTW, what f/w you on? (*#0000# incase you didnt know?) :icon14:
i have looked for firmware to update the phone but cant find it,
my firmware is v3.0617.0.6
I think is the same problem of first N73 firmware versions. It goes to offline, and then never returns to on-line. The only way on N73,was do a phone format:frown: Instead, is better do a phone upgrade to last firmware version. But do a backup first!
can you please tell me where i get the latest firmware to update the phone
Go to nokia.co.uk - support pages for N80 - and do a download of Nokia Software Uppdater tool. Do the upgrade at your own PC!
Hi there
if you have the lastest version of nokia pc suite you can do it via that, or you can do it here.....
i had a look on they pages m8s and can see any files for updating the firmware.
i got the Nokia Software Updater but it dont work
have you got the USB cable?? You'll need that to update the firmware either way, be it thru NSU or NSS and NSU. V3 has an evil history with glitches. And a search on google for your problem shows your not the only one to have it on N series phones!
I own a nokia E60,
i cannot change the profile, the phone stays in offline mode, and when i try to change it, it says "unable to change profile" I tried Nokia Software Updater, but without setting the phone to General mode, the program doesnt advance and it doesnt make the firmware update.
what can i do,
i tried hard reset, i tried different sim cards ....
pls help
thanks
Indeed. I believe the updater needs the phone to be in General profile to work, so catch-22. It sounds daft as it could stick the phone in that mode itself, but anyway.
Could just pop into a mobile shop and they may be able to sort it out. Failing that a Nokia service centre (or I believe you can now 'freepost' your phone to Nokia to fix).
nush wrote:help,my nokia n80 says offline
Ok, this happened to me, the only way i did get it back was using Phoenix 2006, i just set it to TEST MODE, then get it back to NORMAL MODE using the USB Cable then it was done 😎 . Hope this helps.
Cheers 😃
Dx
