Probelm with MMP while converting to nims
10 replies · 3,158 views · Started 19 December 2002
I am trying to convert some avis,mpegs to nims so that i can post it on my site.
Everything goes fine with Preprocessing video,Encoding video
and gets stuck on 1% Preprocessing audio. Then I goto use Ctrl+Alt+del to end the task.
Does anyone know why this happens and how can i convert the videos ?
the chance of you converting avi's and wmv actually every ither type of format apart from mpeg is farily remote! :evil: :evil: :x :x
those idiots at :evil: Nokia :evil: couldn't be arsed to make sure all formats are convertable, so they just have the pro mmc supporting mpeg format, which is a great shame because i have 100's and 100's of stunning videoclips in ever other format apart from mpeg. :cry: :cry:
although i am currently trying to convert these into mpeg format.
anyway i've got quite a few nim video clips, so if you want a few for your website then send me the link andi'ii upload them!
If you have found away of converting other format apart from mpeg then i'ii be grateful for u letting me know 😉 😉
Check also Dazler web site.
Daz has a tutorial for comverting nims, but since My old Laptop is gone, i guess you should ask for it...I dont`t have the loink anymore///
You can convert avi and mpg, all file formats without protected formats.
wmv, asf are protected by M$ it's illegal to create programs that can change them.
But I convert them to avi files and than use Multimedia convertor pro.
But it seems your audio codecs are f*cked up 😉
I have 100's of avi videoclips ready to be converted into nim format, but I keep on getting the message that pro mmc does not support them! :x :x :x :x :x
[quote="The Godfather"]The people at nokia are really "intelligent"... :evil: :x
And they even toch our phones when you send it to them... :-?[/quote]
I agree 100%
[quote="Nokia me"]P4 is no work with Multimedia Converter try with P3 8)[/quote]
what the hell are you on about? :roll: :roll: :roll: :roll:
[quote="4u2nv"]I have 100's of avi videoclips ready to be converted into nim format, but I keep on getting the message that pro mmc does not support them! :x :x :x :x :x[/quote]
MMC Pro can't play files from temp directories like directly from a zip archive or after a download from the net.
Place the *.nim in a real directory and open with MMC, this should give you better results 😉
[quote="Ginzy9210"]I am trying to convert some avis,mpegs to nims so that i can post it on my site.
Does anyone know why this happens and how can i convert the videos ?[/quote]
I have the same problem. I am trying to convert some music videos
from DVD vobs( mpeg2?) to nim. Anyone have any success doing this?
Also, I would like to convert some Anime Music Videos but have not had any success. These are usually in divx 5.* format.
Much Thanks!
