N80 Cannot Power Up
8 replies · 2,833 views · Started 24 January 2007
Try to upgrade my N80 to N80ie but soon after i run the NSU, there is a power trip in my building .... after that my phone goes blank off and when i tried to power up the phone got no respone .... think the firmware got damaged.
Don't think Nokia will honour the warranty as i have altered the product code ...
What should i do now ? Please advise
Thanks ..
This happened to me last night. Have you tried running NSU again? Mine appeared bricked but when I ran the updater again it still recognised the phone so I tried the update again and it went through fine.
Worth a try...
benj wrote:This happened to me last night. Have you tried running NSU again? Mine appeared bricked but when I ran the updater again it still recognised the phone so I tried the update again and it went through fine.
Worth a try...
Or if the above doesn't work then try reflashing several times with phoenix...follow instructions in the first post
I bricked my n80 during the firmware upgrade but managed to resurrect it with phoenix. make sure you have the power adapter plugged in before you try to connect it to the usb port in case the battery has drained in the interim. you also need to specify the device using (i think using open from the file menu) rather than scanning for it because it won't be able to find a bricked device through scanning.
Thanks all ! My N80 is alive again after a few hours of flashing using Phoenix ! Now i am a happy N80IE owner .....
Without the help of all you guys, i would not be able to do it ! Thanks again !!
power_stormy wrote:Thanks all ! My N80 is alive again after a few hours of flashing using Phoenix ! Now i am a happy N80IE owner .....
Cool ..thats what we like to hear 😊..
