Locking folders on 6630
1 replies · 1,968 views · Started 24 January 2007
Is there a way I can lock, hide or put a password on a single folder inside my gallery?
I tried using SmartGuard but it doesn't work the way it should, it doesn't hide the entire folder, sure I can hide every picture within that folder so when you enter it there are no pistures, but I want to deny access to that folder so I don't have to lock picture by picture.
Does anyone know any way this could be done?
Ok, I found something that could be useful Webgate.Advanced.Device.Locks. This program locks the entire gallery and almost every other application on your phone. Have in mind that if you lock your gallery using this program or any other like SmartGuard,... your gallery is still visible and accessable using FE Explorer or any other file manager. So to prevent this you must also lock these programs using Webgate.Advanced.Device.Locks. Then you'll be 99% safe.
