Hello, I am new to the N80 but I have been doing a lot of reading on it recently. I just have a couple of questions to get some things straight. Before you upgrade to the N80ie (v4.0632.0.38) should you first upgrade to the v4.06.0623.0.41 if you don't have that version. Or should you go straight for the v4.0632.0.38 (IE version).
Also, I live in North America and was wondering what is the best product code to use for the N80ie upgrade. Most are using the EURO 3 code for the internet edition upgrade and they report it works fine. What would you reccomend to use since I live in North America. Does the internet edition upgrade differ much from europe than asia? Is it just a language difference. Sorry if a lot of this has been asked before, I'm a newbie. Thanks in advance!!!
Which Product Code to use for N80ie upgrade N80
jrh1983 wrote:Hello, I am new to the N80 but I have been doing a lot of reading on it recently. I just have a couple of questions to get some things straight. Before you upgrade to the N80ie (v4.0632.0.38) should you first upgrade to the v4.06.0623.0.41 if you don't have that version. Or should you go straight for the v4.0632.0.38 (IE version).
you may find that your phone will upgrade ok because it was mentioned on the USA nokia site that the upgrade was possible via NSU...worth giving a go I think before you change the product code.
some info here http://www.allaboutsymbian.com/forum//forum/thread/55471/
