Bemused keeps restarting the phone!!! Argh! and Bluetooth aint workin proply since i tried putting the 2.2.16 driver things on to allow sharing of pictures! Argh! Any ideas?
big problems!
did you store you nokia settings on your computer before you had probs? what bluetooth software do you use? If you use XTND blue manager i have a new driver for it that should help.
[quote="craigc38"]did you store you nokia settings on your computer before you had probs? what bluetooth software do you use? If you use XTND blue manager i have a new driver for it that should help.[/quote]
helo! Wud any software work with any BT hardware? Its a usb bluetooth thing I use... And Something call Widcomm 1.2.2.9 or somat
What exactly are you doing when Bemused restarts your phone? Does it happen on startup, or when you perform some specific action?
[quote="Mental Blank"]What exactly are you doing when Bemused restarts your phone? Does it happen on startup, or when you perform some specific action?[/quote]
On start up... Straght away, the screen fades out as if the battery was removed then restarts, but it doesnt request pincode so the SIM is still active
Well i think i gottit working - But ANY ideas please post!!! As it cud happen again I fear [Plus reference for newbies]
Scary... is the problem still happening? If it is, then try deleting the file c:\apps\bemused\songlist.dat using a file manager and let me know if that stops the crash.
[quote="Mental Blank"]Scary... is the problem still happening? If it is, then try deleting the file c:\apps\bemused\songlist.dat using a file manager and let me know if that stops the crash.[/quote]
Well it seems like a new problem now!!!
When i look at bemused [after the com port is connected] Iit says unknowen command or sumthing and a load of rubbish - and the com port stays open for only about 30 seconds
P.S. I;ve got a new thing - a blue button next to the quote button - Is this new?
Does PC Suite still work OK? Or is this broken too? It sounds like there's some problem with the Bluetooth software on the PC...
this used to happen to me as well....when i would start it, the screen would fade to white, and restart the phone
cant remember how i sorted it \
oh yeah.....i uninstalled it
and then reinstalled it...i think that was it
to be honest i cant remember....but its nothing shady.....so dont worry )
