How to Master Clear N91
3 replies · 12,612 views · Started 25 January 2007
Hi
I have done a master reset and have formatted the hard drive on my Nokia N91. How do I do a master clear on the phone memory so that it is back to how it was when I first bought it?
thanks in advance
Y2K
*#7370# type this on you mobile (idle Screen) and follow the instructions then u will get a Master Reset
Wirelessly posted (Nokia E70: Opera/8.01 (J2ME/MIDP; Opera Mini/3.0.6560/1630; en; U; ssr))
{Green}+{def3}+{*+} all pressed at the same time when powering up.This is a hard reset-so your phone will take a little bit longer than normal time in booting up.
The soft format is what nipon said,it doesnt work the way you want you could then try the hard reset method.
