help,
i got phoenix and it says nokia dongle. how do i install it
help,
your gonna need to use the search option.. and get reading... should all be there. Make sure you follow it step by step else you'll have nothing better than a paper weight! :icon14:
m8 tell me i really need to know
nush wrote:m8 tell me i really need to know
There is only one way you will upgrade your N80 and thats to read and follow the thread that Kontraband told you to look at, its impossible for anybody here to give you step by step instructions.
