N70 - problems with unknown file format
2 replies · 3,720 views · Started 25 January 2007
I've been dealing with certain problem, which I hope you could help solving - I'm totally newbie in mobile stuff, so i'm really counting on you 😊
Friend of mine prepared flashLite presentation that I'd like to send to people over the bluetooth. Everything goes smoothly on E series Nokia phone - but it didn't go too well on N70.
N70 had FlashLite installed (it wasn't preinstalled), after sending the swf file over bluetooth it goes to inbox, but it can't be opened or saved to any folder.
There is no such problem if you upload the swf file using USB cable and copy it to "Other" folder.
Have you ever encountered such a problem? And have any idea how to solve this problem?
If it can't be distributed over the bluetooth, do you have any idea how it could be distributed to many users at the same time at the same location?
Hope to get some help from you, best regards
petes
Thanks for reply Liquid_Li0n - the solution you advised is okay when thinking of advanced user - I'm looking for something simpler, that wouldn't require from people loading and installing any extra software on their's phone.
Let's consider this situation to take place in some exhibition area, where you are offered flahs lite presentation of product or something else. how to easily upload that kind of content to user?
