Boot problems with N70
1 replies · 1,812 views · Started 26 January 2007
Hi all!
I just installed an hacked version of tony hawk pro skater for ngage on my n70...but (after a couple of minutes) i've uninstalled it by removing its files from the system/apps directory
now i can't boot my phone with my mmc in....because it doesn't start!
it stops on the first "NOKIA"...
if i remove my mmc i can normally boot my phone and use it as usual
How can i make my phone boot with mmc in? i don't wanna format it...
That's the price for using cracked software. I'm afraid that you will need a format afterall, if you want your device to work again... Just joking. Delete the System folder from your MMC with a card reader and it will work again, but don't ever install again NGage games on the N70.
