TomTom SAT NAV File Corrupted
2 replies · 3,968 views · Started 26 January 2007
When i try to install Tomtom sat nav on my Nokia 6680 it tells me that the file is corrupted?? iv`e turned of the cert check ????
what can i do to get this software on???😡
Thefires
thefires wrote:When i try to install Tomtom sat nav on my Nokia 6680 it tells me that the file is corrupted?? iv`e turned of the cert check ????
Thefires
'Install'? But it comes on a MMC Mobile card! It should just 'be' there when you put the card in?
Steve
How are you installing the software onto the MMC? Have you got a pre-installed MMC bought from TomTom, or are you copying a ripped version from cd onto MMC?
Also, make sure you have TomTom 5 , NOT TomTom6 ( which will not work on a 6680).
