queries regarding Upgrade to N80i
10 replies · 3,444 views · Started 27 January 2007
Hi
I have upgraded my firmware using Nokia Software Updater, the firmware version now is V 4.0623.0.41
Is this upgrade enough to use Truphone, I guess not, as i dont have SIP/VOIP option yet,
now my question is, flashing N80 to N80i might result in a dead phone (as reported by few users here), but is there any way to come round, if that happens??
all i need is to use Truphone, if that works in this upgrade (V 4.0623.0.41) then i wont go for the flashing.
help me please
sifte wrote:Hi
help me please
You need to reflash to N80ie firmware, you currently have N80 firmware, it is possible to bring a dead phone back to life by reflashing several times untill the phone starts working, but I cant say this will happen in every case, if it does not then you will have to send your phone back, but they may not repair under warranty because you will void the warranty by upgrading yourself, if they notice.
Using NSS and NSU is a pretty foolproof way as long as you leave your phone for about 30 mins during the flashing process..
thanks cash for your reply. that was really prompt !! :icon14:
I will upgrade to N80i but the download links provided in the thread are not working.
is there any other way to get the softwares ?
cheers
sifte wrote:thanks cash for your reply. that was really prompt !! :icon14:
cheers
you just need NSS from the download links if you are upgrading with Euro firmware, (as long as you have Nokia Software Suite installed because you need the cable driver)
change the product code to Euro1 (seems to be the most popular), follow just the NSS part of the first post.
and then download and install NSU (nokia software updater) from Nokia site, plug your phone in and then upgrade the firmware.
i have Nokia PC Suite and Nokia Software Updater (NSU) installed already
im trying to download NSS using the folllowing link
rapidshare[dot]com/files/5911866/nss10383.rar
but it takes me to no where !! is it working with you, is it my ie (ie 7) where is the problem :s i have also tried using firefox
any help ?
yeah, works for me ok... you need to go to free unless you have an account with them and get the ticket to download... unless there is no wait.
Yeah just downloaded it, would u be able to flash a 7270 with this and put a eastern european languages on it?
no reason, it was just a file one of our users had uploaded so we knew it worked 😉
Good to have to true link too tho Mr Anderson 😊
