Digia ImageSpy: Digia ImageSpy is an innovative application for camera and MMS enabled Nokia 7650/3650 devices. Now the camera can be set to monitor its neighbourhood and raise an alarm when motion is detected. The alarm can be silent, when picture is taken, message (MMS/SMS) is sent or call initiated to predefined address. The alarm can also be set to play user selected sound files. Repeated alarms and delays before and after alarm are supported, so the application can survey its target by recording and reporting any new motion detected for longer period.
MMS Cam: This camera can be queried with every MMS supported mobile phone. Just send the command message '//YMMSCAM' and in the twinkling of an eye it takes a photo and sends it back via MMS.
The greatest party gag ever. Your guest can check whether the meal is ready or what's going to be on table later...also mama can check if the children at home behave themselves. You can also check if it's a good idea to drive out to your weekend cottage - just check the weather there and then decide. Or Or Or...
The access of the camera can be confined, so that only messages of specified senders will be accepted. Sent photos can be archived on the phone. Taken photos can alternatively be saved with higher, normal or lower image quality.
Fortune: Fortune is a collection of 7000+ fortunes, quotations and wise words from around the world. If you know the Linux tool called Fortune, you know what you'll get: entertaining, shorts texts, that can enlight your day just by browsing through them.
Tastes are different, and so are the categories in this package, which you can individually access by enabling or disabling them -- create your own personal fortune package with only those categories you like most!
You're bored and don't know what to do? Launch Fortune on your Nokia 7650 and start the slideshow, which will present you with a new fortune every 5 seconds!
For more info and screenshots see Handango's Symbian Software site!
