Problems sending a MMS
3 replies · 1,673 views · Started 27 January 2007
hello everybody!
im new to this forum, and i just received my n80, and i love it! but i have a problem receiving MMS, it says i must define an access point, and i have no idea how to do that, i have cingular and have tried a couple of times, but couldnt get it to work, if you guys could help me out, or let me know if there was a past post on this problem before, let me know! thanks!
Many networks (but perhaps not Cingular) can deliver the required settings automatically so that things like MMS just work.
And there's the "Settings Wizard" app on the phone (if Cingular hasn't requested it to be removed), which you can use to retrieve the settings otherwise.
You can also call Cingular and ask them to send you a configuration SMS, then open the message and choose the save option.
Checking the Cingular's web site might also be an option; many operators have a way from their web site to have the settings sent,
Finally, there's the Nokia web pages where you can order settings for many operators:
- USA: http://www.nokiausa.com/support/settings/1,1921,,00.html
- Europe: http://europe.nokia.com/A4144889
jpenarejo wrote:hello everybody!
Hi jpenarejo! :wavey:
N/A has left some valid suggestions. I hope you can sort it.
The fact that you have said its causing a problem to 'receive' makes me wonder if your trying to download the image from a webportal instead of receiving it to your handset?
Either way.. if you followthe previous post ideas... you should be sorted.
