Some of you may recall my post about the weird issue I was having with my alarm. Basically I would set my alarm for 8:00am and if I woke up at 7:00am I would power the phone on in case someone was trying to reach me and go back to sleep. With all of my old Nokia phones the phone would power on and when the alarm time came around the alarm would sound. With my e70 I would power it on and even if before the alarm time the alarm would sound and I would have to turn it off and reset the alarm. I thought this was an issue with the new phone and it's alarm but I believe I've discovered the problem. I happened to watch the phone one morning and for a split second as it registered with the system I saw the time go from the current time, to exactly one hour ahead and then finally back to the current time. In this split second error the alarm would go off because for that second or so it WAS time to sound the alarm. So, it's not the alarms fault... it's the auto time adjust feature.
For whatever reason the phone wants to adjust the time ahead an hour before correcting itself when it powers on. What is causing this? I disabled the auto set by system feature and it's solved but this is a band aid fix for the real problem. What is causing this and how can I fix this? It seems as though it's a firmware glitch more than anything and is most likely out of my control.
Input and ideas are greatly appreciated.
