how to find out my lock code? I've inputed lock code and now forgot it.when I change my sim and put in another one I gotta digit unlock code which I don't know cause I've changed it
PHONE UNLOCKING???????
I had the same problem...
install Psiloc's tool, it will allow you to reset the phone settings to their factory default without having to input the lock code.
The best thing is that this will not zap your installed applications or anything like your gprs settings, or messages.
where will I download it and will I loose my phone book and all the games and app that I've installed???
[quote="pandemonium"]where will I download it and will I loose my phone book and all the games and app that I've installed???[/quote]
Firs,backup your phone by Pc Suite,it will backup everything except for java apps.That is it.
When I did it the only things I lost were the modifications I had made to the general and silent profile, the data and time and what image i was using for the standby mode.
www.psiloc.com
download their filemanager
so....what do I do after installing efile manager???
im not sure if efileman can help you with your prob. your phone is locked you cant open it because you forgot the code - so how do you operate any apps to solve your problem when you install them???? :-? i suggest you give your local NSC withy regard to this problem. im sure they'll be able to help you out.
Maybe he did not set the power on security code prompt. So it only prompts upon changing of the sim.
my phone is open and working with the old sim which he rememberd but upon entering new one it asks for unlocking code wich means I'm able to download any apps without any problem.
under tools-settings-security-phone and sim-LOCK IF SIM CHANGED ...I've chosed yes ....that's why I can't change my old sim
