Nokia 9300i Stereo Bluetooth Compatibility
3 replies · 3,240 views · Started 28 January 2007
Hello All, I am looking to get the new Nokia Stereo BT Headset HS 12W for my 9300i. I keep seeing conflicting compatibility issues with regard to the A2DP profile for this phone.
Does anybody know if the heaset will support true stereo playback on the 9300i, or will it not work? Also, having the FM radio in this heaset is a plus since the 9300i does not have that in the phone. If not, is there another model which will?? Thanks!!!
Any chance the the MSI Blueplayer will overcome this limitation? I have seen some limited info on that software. Thanks.
I own a2dp headphones, and while i can listen to stuff in mono and answer calls, i cannot use a2dp. Do not expect this to change unless some kind of miracle happens or you fall into an alternate universe.
