Hope this helps part 2...
Changes when upgrading from firmware 4.03.38 to 5.03.08
Nokia Mobile Phones Service Bulletin No. SB-023/07.10.05
Telephony
- FDN phonebook stability improvements.
- DTMF play speed corrected.
- Improvements to incoming call handling when playing games.
- CLI shown now correctly after a fax call.
- Improvements to automatic redialling.
- Correction for reset problem when receiving forwarded call from switchboard.
SIM / USAT
- When changing active code from PIN to UPIN, UPIN is asked, too.
- SAT Play tone volume increased.
- Phonebook�s thumbnail images shown when scrolling.
- Service provider name shown correctly when SPDI read from USIM.
Audio and Video
- Corrections to RV8 decoder algorithm and MP3/AAC decoder.
- Playing clips without information of number of audio channels improved.
- Streaming quality enhanced.
- Audio routing corrected for Nokia Cark112.
- Pause/resume functionality improved when using Vidiator server.
Browser
- Browser stability improvements.
- Browser behaviour improved when browsing certain pages.
- Language selection for google corrected.
- Pages with background wallpaper now shown correctly.
- WAP email PDP context drop issues solved.
- Resuming after service lost works now correctly.
Messaging
- Stability improvements to IMAP mailbox.
- Mail inbox update is now working correctly.
- Extra line feeds removed from email.
- Notification added when rights object received in inbox.
- SMS sending failure for multiple addresses corrected.
- SMS proactive command interpretation improved.
- Receiving Chinese SMS containing more than 45 characters no longer causes shorter standby time.
- Chinese input added to mailbox user settings.
- Support for Unicode SMS character counter added.
Video Call
- VT call behaviour improved if audio channel is closed and reopened with different bit rate.
- Unmuting audio sending during video call is now possible.
- Overlapping in calling to video mailbox corrected.
- Video sharing stability improved.
- Video Share item added to incall option menu.
- Share video option no longer disappears from option�s menu after 3rd party MT call.
- Video call can now be established correctly with Ericsson VIG.
- THAI language supported now in Snowboard game.
- New error note added if MMC formatting fails.
- Stability improvements for FTP upload.
- Extra security code added to prevent users to play non DRM protected AAC files by renaming the file.
- Correction for USSD channel closing.
- Boot-up ensured even if there is corrupted MMC or corrupted font files in terminal.
- Access point configurator updated.
- Operator name list updated.
- Bluetooth stability with other vendor�s headsets improved.
- Default image resolution changed from Normal to High.
- SyncML client temporary data excluded in backup.
- LifeBlog account registration succeeding.
- Media gallery handles better long play list names and large images.
- Alarm clock volume adjustments.
- Validity check added before setting currency symbol.
- Dialup works now after USB PictBridge printing.
- BT deactivation behaviour with certain headsets improved.
- Folder path name length extended to max. 255 characters.
- All streaming links played correctly from .ram file that contains several streaming links.
- New error note added for out of memory situations.
- Java Install/Notify problem corrected.
- Support for multiple BT connections.
- Serial port signalling handling improved.
Changes when upgrading from firmware 5.03.08 to 6.03.08
Nokia Mobile Phones Service Bulletin No. SB-067/16.03.06
SIM / USAT:
- FPLMN list updated on USIM.
- Axalto USIM card detection improved.
- FDN activation and deactivation with Axalto USIM card improved.
- SMS sending from Gemplus SIMATK improved.
Audio and Video:
- Unknown Hi-fi headset default volume decreased.
- RTSP Teardown now sent after streaming is stopped.
- Video player stability improved when playing invalid MP4 file.
Browser:
- Improved handling of large web pages when rendering them using "By quality" option.
- Handling of unescaped # character in web page improved.
- General Browser stability improved.
Messaging:
- Fixed phone freeze problem with some T9 combinations.
- General T9 robustness improved.
- Receiving problem with DRM protected MMS fixed.
- Changed the handling of DIV tags in order to remove unwanted linefeeds.
- Fix the problem of corrupted Hebrew characters in received email.
Video Call:
- Phone reset problem during video sharing initialization corrected.
- SMS and Video call alert tones both played, if received at the same time.
- Video Call initialization phase robustness improved.
Misc:
- Handling of corrupted jpeg files improved.
- Phone reset problem with Motorola BT headsets fixed.
- General connectivity robustness improved with BT car kits.
- Bluetooth pairing interoperability improved.
- Problem to access menu with certain SIM cards corrected.
- Logs GPRS counter clearing improved in certain situations.
- Improvements in weak field performance.
- Phone reset with certain SIM and SMS combination corrected.
- Snooze option disappearing problem corrected.
- Removed possibility to change profiles when SIM not inserted.
- MAP service UnstructeredSSNotify functionality improved.
- Network connection failure not shown anymore after using PUK code.
- 3gp file recognition from header (extension independent recognition) improved.
- USSD message not cleared automatically anymore after automatic acknowledge sent to network.
- Sound quality of music track is no longer affected by camera shooting.
- Current consumption improved.
- Usage of SRES parameter improved.
- Added support for Network error code "00011010 Insufficient Resources" in networks that doesn�t support multiple PDP context.
- GMS network selection improved in case GERAN is preferred.
