hi i have a nokia n80 in the USA and i am using cingular and they say they are gettin umts or utms??i dont know what it is but what do i need to use my second camera as a video confrencing???...please help im eager to find out:con?
what kind of service do i need to di video confrencing in USA? i have cingular
UMTS = WCDMA = 3G
The WCDMA networks support video calls, but it will not work on "regular" GSM/GPRS (EGPRS) networks.
WCDMA in North America works on the 1900MHz frequency band, and elsewhere in the world 2100MHz is used. I don't know if there's a North American version of the N80 with 1900MHz WCDMA, or if it only has 2100MHz WCDMA (which means it will not work on a North American WCDMA network).
N/A wrote:UMTS = WCDMA = 3GThe WCDMA networks support video calls, but it will not work on "regular" GSM/GPRS (EGPRS) networks.
Nope...there's no US version of N80. I have a N80ie here in the US and no 3G :frown:
You can use Cingular EDGE or WLAN for video conf. though
Hope that helps,
FluxCapacitor wrote:You can use Cingular EDGE or WLAN for video conf. thoughHope that helps,
N80 for a WLAN video conf. Hmm, i never thought of that...
my mistake i forgot to mention i got my N80 from india it is not a US version....i called cingular and they say they are getting umts by this summer becase ATT wants video conf....so i dont know i guess we'll have to wait:frown:
armada741 wrote:my mistake i forgot to mention i got my N80 from india it is not a US version....i called cingular and they say they are getting umts by this summer becase ATT wants video conf....so i dont know i guess we'll have to wait:frown:
That's true on Cingular getting UMTS...but, just like what N/A said before the US 3G band is 1900 and N80 only supports 2100
You can have video call on N80 using TiVi.
