I have just upgraded my orange N73 to N73ME but I have lost my option for line 2 (ALS).
Are there any N73ME Product codes that will still let me use my line 2?
If not are there any tools that will allow me to enable my Line 2?
Thanks in advance.
Al
Thanks in advance.
Al
I believe there is orange firmware now that is beyond ME so changing your product code back to the original should see the NSU update you to the latest firmware.
You won't have the music player as ME but it may be that Line 2 will function.
Bear in mind though there is no going backwards as that would be the latest firmware.
Gavc,
Thanks for the info.
I have read in another forum that the IE software supports line 2 and I beleive it has the same music player as ME so may try this first.
Otherwise I guess its back to the Orange firmware until they bring out an ME or IE version.
Quite fancied the 3 firmware with messenger and skype options but not sure about this???
Anyone have any experience?
Thanks again.
All Nokia firmwares support Line 2, you just have to get it turned on.
I believe a SIM update is needed to get a generic firmware to enable the Line 2 functionality.
