:con? 😞 Can anyone help me out..??....I have obtained a copy (DVD) of TomTom Navigator 6 (Symbian S60 ver. 9.01) I have loaded all folders and files onto a mini SD which I have in my Nokia E61. The instructions that came with the DVD are as follows:
1) Extract TomTom_6.010.rar to a new directory on your PC
2) Connect PC to Phone via datacable
3) Copy the ENTIRE contents of the new TomTom directory from 1) on the PC to the MEMORY CARD on your phone
4) Disconnect phone using the 'Safely Remove Hardware' Icon from the XP Tool Tray
5) TomTom will auto-install on the phone
6) Reconnect Phone to PC with data cable
.... Unfortunately...TT did not install automatically as stated...and no matter how many methods I try...I am still unable to load TTNav6 on my phone...
I do not see anywhere *.sis files (Symbian installation files)�.I would have thought this is important..???...all other software installed on my phone used *.sis files for installation�???
Anyone out there with any ideas....??
Ta. Mike 😞
