Hi. I want to delete all calendar entries on my E61 because I'm about to sync with a web service and don't want rogue entries on the phone overwriting my true web-based master calendars.
How do I do this? I was told I could do it from Options > Delete > Delete all - but I don't have that option on the version of the software on my phone.
I've also gone and deleted cldrmdb.dat and cldrmdb.crc in C:\System\data\, which you'd think would be the calendar database - but to no avail.
How do wipe it clean, please?
Thanks!
Another way, is do a sync process with an empty Outlook, and make the Outlook mandatory on that task.
I'm on a Mac, I'm afraid.
Thanks, Rafe, for the tip - I knew I saw such a tool recently.
No tools required: Make sure the Calendar is in Month view on the phone. In Month view, hit "Options", choose "Delete entry" and then "All entries".
Correct... But I supposed that he already try that, other wise is not necessary complicated ways to do that... But maybe he miss the direct way🙄
Most likely the Calendar was in day or week view, where the option doesn't show up (and not in month view, which is the only case where it is visible).
And, as far as I remember, this is also documented in the phone's User Guide.
Could be that. I don�t remember about user manual either.
