Pc suite adn outlook 2000
4 replies · 2,480 views · Started 19 December 2002
I have outlook 2000 with winxp.
when i'm going to syncronize the agenda is all ok. When I'm going to syncro the contacts, the program stopping on opening database.
how can i do?
thank you
From personal experience, when you want to synchronise contacts, outlook will pop up a little window asking if you want to allow a 3rd party program to access you e-mail lists. I guess it's some kind of protection against viruses or something. Anyway, just select sellect "allow for 1-2 minutes" and then click ok/allow. But I'm using Office XP so things might be a bit diferent for you.
yes... but in this case there isn't pop, the program is stoppen on opening database....
[quote="malau"]From personal experience, when you want to synchronise contacts, outlook will pop up a little window asking if you want to allow a 3rd party program to access you e-mail lists. I guess it's some kind of protection against viruses or something. Anyway, just select sellect "allow for 1-2 minutes" and then click ok/allow. But I'm using Office XP so things might be a bit diferent for you.[/quote]
How long does the sync take? You can specify how long the pc-suite gets access to outlook afaik, so make sure the sync doesn't take longer.
the syncro of agenda/calendar is very fast, when start the syncro of contacts the programs stop on: opening database and the sincro don't start. After few minutes I close the program.
I have also winme on the same notebook, and the sync works fine.
[quote="netzmeista"]How long does the sync take? You can specify how long the pc-suite gets access to outlook afaik, so make sure the sync doesn't take longer.[/quote]
