Help! I encounter after many themes (>10) install on my memory card, new themes appear under 'Themes' selection but my old installed themes gone! I'd check the 'Log' files its show ddmmyy themes install (this mean the missing theme still in my phone N80). Anywhere can locate my missing themes? And i'd try on re-install again those missing themes end up 'Unable to install'. Any clue?😎
Themes missing
Use the search and you'll find the answer,it's been discussed loads of times.
