Software to sync with Outlook XP (2002)
7 replies · 4,017 views · Started 19 December 2002
Hello,
I am searching for a software to sync my nokia 7650 with Outlook XP (2002). I can only use Contacts or tasks from Outlook 97,98 and 2000 in The PC-Suite for Nokia 7650.
Or has anyone an idee how I can export my Contacts in an format which is compatibel with the pc-suite (it is also possible to import from 9210 or Outlook 97.98 or 2000)
Thanks for help
😮ops:
I'm syncing with outlook XP with no problems. Are you talking about using Windows XP or Outlook XP? Because I know that some people have been having problems using the Nokia Suite with Windows XP. I'm running Windows 2000 with Office XP, and I am not having any problems with Nokia Suite.
Outlook XP and Windows XP Pro actually work fine with 7650. Make sure to click "Yes" when it asks if it can allow access to your email addresses for 5 minutes.
Sure you got the most recent version? cos:
[quote="nokia.com"]PC Suite in English
Version 1.2.0, updated 19-Feb-03
These are some of the new features in version 1.2.0:
Windows XP is now supported
Microsoft Outlook XP synchronization is now supported
[/quote]
[quote="aCiDByTe"]i keep getting FAILED TO OPEN OUTLOOK. Can someone help me ?[/quote]
Make sure that your office isnt in "special state" on startup, I mean that when you start outlook it wont ask you any registrations of new mail accounts or ask to make outlook default mail program or something like that...
To avoid these prompts start outlook normally from outlook-icon and make sure that it wont ask you anything in the future.
hhelgo wrote:Are u sere u have Outlook Xp or just plain Outlook Express?
I am having the same difficulties. I can only sync Calendar and Contacts with Windows XP, Office Xp, Pc Suite and Nokia 6600.
Please state what versions of software/os/phones you are using to allow you to sync everything with outlook????
Thanks.
PF
