I too can't see calendar entries on my standby screen. I have turned every possible Active standby plug-in on, but still if I go to calendar and create a meeting for today, nothing gets displayed on the standby screen.
Any ideas? It would be great if I got this working. Oh, and I have RTFM - it's bloody useless...
Mike5
mike5 wrote: I have turned every possible Active standby plug-in on,
Are you sure you have ALL the plug-ins turned on?
There are more plug-ins than you see in that first screen (ie the screen of plug-ins with tick boxes that is shown when you are in Tools-Settings-Phone-Standby Mode-Active Standby plug-ins) .
So once you get there to that screen, use your joystick to go down all the way and make sure you see "Organizer" and check the box beside it. "Organiser" is the item just below "Active standby mailbox".
If that doesnt work, I dont know.
Yes, everything is on. Anyway I'll try to get it to work, if it doesn't I'll take it to the Nokia representative and have him fix it.
Tnx. It's working after all....
