I have my Nokia N73 and i have entered a product code into the Nokia website and downloaded the so called Music Edition firmware for my N73.
I used nokia software updater (NSU) but it said it upgraded but it stayed with the same old firmware.
I was wondering what do you have to do to change a standard T-mobile N73 to the music edition.
Please advise me on how to change it. :icon14:
Download NSS and change your product code to 537289, then run the update again with NSU.
NSS? where would i get that from?
Also will it brick my N73?
http://www.b-phreaks.co.uk/software.htm
Changing the product code with that is fine, and id say from reading on here than 95% of upgrades using NSU are also fine.
Its worked on 3 different N73s for me.
Make sure you got a decent, stable connection to the internet when you do the upgrade, and also dont unplug your phone from the computer when its all happening to avoid problems.
^ oh right
So it should work by following these steps.
Is there anything else i would have to know before i attempt this?
Thanks tho..
Dont think so, i did it based on knowing just what ive said, worked a treat...
Just make sure you back up you phone to its memory card before you begin as updating the firmware will wipe the phone clean.
Matt. C i would like to thanks you for converting my N73 to the music edition in too seconds, i also put the latest firmware on it... thanks alot.. much appreciated!
Thanks Kaz
have flashed phone with code given above, when trying to upgrade with nsu and it says latest software already installed, any ideas how to get music edition firmware on phone?
cheers:con?
Whats your firmware version at the moment?
enter *#0000#
current software v3.0638.0.0.1
this a standard n73 not music edition which i want
cheers
have now installed the music software, you have to put a 0 in front of the number, lol
cheers for the help
Hi, I have a T-mobile N73. I have changed the code to 0537289 with NSS. When I try to upgrade the firmware to ME with NSU it says no updates availalbe, internal module error.
My firmware at the moment is v3.0638.0.0.1 30-10-2006 RM-133 Nokia N73 (92.02)
Any help.
^ i had a T-mobile phone aswell..
What you do, is you change product code of your phone with NSS,
But then add a fake product code into the nokia website and download the music edition firmware and use that to update ur phone with Nokia Software Updater.
Use a product code from the sticky thread called product codes
Thanks for your reply. I can change the phone code with NSS ok, but I don't know what you mean by a fake code with the Nokia updater, can you tell me more please.
Thanks.
If your N73 product code has been changed to 0537289, then NSU will show that there is an update to a new ME firmware, V 3.0705.1.0.31.
Just connect your phone via USB, run NSU and it will do this for you automatically.
Hi, thanks i've managed to change it to the ME. A couple of questions, can you not close the media player in this version & is there any where to get free album art covers to display.
Ta.
Music Player stays on by default. You cannot turn it off. It's no worry as it occupies about 8.5K of memory.
As for album art, search Google images for whatever you need. I have responded to your other post with details on how to add them.
My N73 Shows
V2.0628.0.0.1
10-07-2006
RM-133
Nokia N73 (56.02)
Can i Also upgrade my phone to ME!
I M Frm INDIA!!!!
just to let everyone know i just upgraded my O2 N73 to the ME firmware via the product code change. my old code was 0539976 i changed to 0537289. i had problems backing up my phone but rectified it by taking out the mem card. i also done the update without a mem card in. i was crossing my fingers as i bricked my original n73 back in nov but this time all went well😊
