SiP on N80 IE? Pleeease help
13 replies · 4,548 views · Started 01 February 2007
Hello All,
I can't get my N80 to registre with voipbuster.com
How should i set up my phone? The information from voipbister.com is:
Software configuration
General
SIP port : 5060
Registrar : sip.voipbuster.com
Proxy server : sip.voipbuster.com
Outbound proxy server : leave empty
Account name : your Voipbuster username
Password : your Voipbuster password
Display name/number : your Voipbuster username or voipnumber
Stunserver (option) : stun.voipbuster.com
I just get the message, that it failed to registre
have a quick search for SIPgate.. theres some settings on there, plus TruPhone too
also, you may need some router config.
kontraband wrote:have a quick search for SIPgate.. theres some settings on there, plus TruPhone too
Hello,
As far as I can see, those programs wants you to youse their network? Is there some way I can use the voipbuster ? (since it is 100 % free)
ChrDk wrote:Hello,
goto tools > settings > connection > sip settings and enter all the info there..
e then goto internet tel settings and create a new profile named voipbuster and use the sip settings you just entered
ChrDk wrote:Hello,
Found the solution. Thx.
I went to their website and it has a lot of free landline calls: this seems too good to be true
Edit: anybody know any free landline calls to ukraine?
SpeTz wrote:I went to their website and it has a lot of free landline calls: this seems too good to be true
you have to be careful and read the small print, sometimes the free calls are limited, sometimes you have to put a certain amount of credit on the account to qualify for the free calls...just be careful, the only tru free calls sip service I know of at the moment is Truphone, and that will change at the end of March when they withdraw the special offer..
SpeTz wrote:dammit i hate those stars** that show that its fineprint somewhere
I looked at it before and then read the smallprint, I will stick with truphone until their offer ends, then re-evaluate what's around ..
hi, yeah i have a voipcheap account (same company -they have loads of names) allthough the deal is limited to 120 days from each topup and limited to "300 minutes per week of free calls" its still not bad (you get to keap the credit after the 120 days and the rates arent bad). i got the account long before my n80, but i still havent upgraded to n80ie i was waiting till it can be done with nss, now im waiting till i have some time free to reinstall everything afterwards.
