Errors from AppTestLite
5 replies · 0 views · Started 03 February 2007
I've tried running AppTestLite on my game on an N90 and it comes back
with 4 errors that I can't see as errors in my game.
1: FAILED PKG-04 Uninstall provides complete removal of all files
and the installed data.
The only errors I can see in the log are:
<log time="21.812500" type="dll" name="AtFileSnapshot">NEW
C:\Private\101F7989\</log>
C:\Private\101F7989\sms\</log>
<log time="21.828125" type="dll" name="AtFileSnapshot">NEW
C:\Private\101F7989\sms\smsreast.dat</log>
C:\Private\101F7989\sms\smssegst.dat</log>
C:\Private\101F7989\sms\wapreast.dat</log>
Which indicates the only problem is the test suite itself creating new
files.
2: FAILED PKG-07 UID and version for platform compatibility is
appropriate for the target device.
Not sure what's up here, the relevant parts from my .pkg file are:
#{"Oval Racer"},(0x10003FF4),0,54,0
; Supports Nokia Series60 Platform 2.0 Specific features
(0x10200BAB),0,0,0,{"Series60ProductID"}
Any idea what the problem is?
3: FAILED PHN-01 Service Interruption. (call, SMS, MMS, alarm,
charger)
The relevant part from the log I can see is:
<log time="144.234375" type="dll" name="AppScreenMonitor">Searching
for image 'C:\system\apps\apptestlite\tests\alarm.png'.</log>
<log time="159.375000" type="dll" name="AppScreenMonitor">Timeout
expired. Execution terminated.</log>
I'm guessing it might be to do with the app running in v8.0
compatibilty mode, or that it uses OpenGL ES direct screen access
which might affect the ability of the test suite to read back from the
screen. But it certainly looks fine when I test this manually.
4: FAILED MEM-01 Low Memory Startup.
I've run my own extensive low mem tests which showed up nothing wrong
under WINS. So test it on real hardware I hacked some code into my
start up to alloc then free a huge amount of memory which I could then
move around the startup code to try and narrow down where the error
occured.
It seemed that putting this right at the start still hit the errors
indicating that they are most likely in the system code not mine.
These errors seem to occur before the code even hits my appui
constructl
<log time="3.062500" type="dll" name="AtStartupTester">[heap 24576
bytes] Panic: Font Utilities 0 in phase Construction</log>
<log time="3.125000" type="dll" name="AtStartupTester">[heap 25600
<log time="3.171875" type="dll" name="AtStartupTester">[heap 26624
<log time="3.218750" type="dll" name="AtStartupTester">[heap 27648
<log time="3.265625" type="dll" name="AtStartupTester">[heap 28672
<log time="3.359375" type="dll" name="AtStartupTester">[heap 29696
<log time="3.406250" type="dll" name="AtStartupTester">[heap 30720
<log time="3.468750" type="dll" name="AtStartupTester">[heap 31744
After those when it gets to my massive alloc I then get a ton of the
following errors:
<log time="3.656250" type="dll" name="AtStartupTester">[heap 32768
bytes] leaked 20 heap cell(s), 3 handle(s) and 0 request(s)</log>
<log time="3.828125" type="dll" name="AtStartupTester">[heap 33792
<log time="4.015625" type="dll" name="AtStartupTester">[heap 34816
<log time="4.203125" type="dll" name="AtStartupTester">[heap 35840
with finally later on as the heap gets bigger finally getting a load
of these errors:
<log time="88.515625" type="dll" name="AtStartupTester">[heap 152576
bytes] Panic: KERN-EXEC 3 in phase DestroyEnvironment</log>
<log time="89.656250" type="dll" name="AtStartupTester">[heap 153600
All these seem to be happening as a result of hitting my instant leave
where I allocate 200K right at the start of my appui ConstructL so I
can't see they're anything I'm doing wrong.
Does seem a bit much that the we're expected to pass symbian signed
tests haven't even been run on the builit in app startup code.
http://www.GreatApe.com
http://www.Oval-Racer.com
Hi Steve
It may be that there are no errors. N90 is based on S60 v3, and as you will
see from www.symbiansigned.com, there is no version of apptestlite (yet) for
S60 v3. If you are using the one for UIQ3, this might explain your errors.
Regards
Hamish
"Steve" <[email protected]> wrote in message
news:[email protected]...
> files.
> charger)
> occured.
> constructl
> following errors:
> of these errors:
Correction. N90 is based on v8.1.
"Hamish Willee" <[email protected]> wrote in message
> Hi Steve
will
for
> Regards
> Hamish
> news:[email protected]...[color=green]
> > files.
> > charger)
> > occured.
> > constructl
> > following errors:
> > of these errors:
>[/color]
OK, so spent a little more time on this. See comments below preceeded by ##
> > Hi Steve
> will
> for
[/color]
errors.[color=green]
> > Regards
> > Hamish
> > news:[email protected]...[color=darkred]
> > > files.
[/color][/color]
## Try UID 0x102032BD, the value for S60 v2 FP3. I'm guessing that it simply
checks against product ID for this device and pops up the warning (which
would be a bug)
[color=green][color=darkred]
> > > charger)
[/color][/color]
## Could be as you've said. Certainly SymbianSigned test house will run the
test manually.
> > > occured.
> > > constructl
> > > following errors:
> > > of these errors:
> >[/color][/color]
## What happens on low mem if you run using TOOL2? This tool starts testing
above the area where there are known low memory issues with S60 application
framework.
[color=green]
>[/color]
On Fri, 22 Sep 2006 05:38:12 -0000, "Hamish Willee"
>would be a bug)
I've tried doing that on the N90, and also running with the original
on a 6680 and both are failing, so guess that's not the issue.
Unfortunately there's no extra log created for this test so hard to
get any idea what's wrong.
>> > > charger)
[/color]
>test manually.[/color]
Think I'll just assume this one is done to something in the test
suite, quite complicated to handle automating this sort of test and
easy for it to get it wrong somehow.
>> > > occured.
>> > > constructl
>> > > following errors:
>> > > of these errors:
[/color]
>framework.[/color]
Is TOOL2 another program I can download from Symbian Signed? Stuck for
access to that at the moment (see forgotten password thread 😊)
I've tried the normal low mem tool and with the massive alloc cheat at
the start it reports no failures, but 21 mem leaks.
The same code on my 6680 passed the lowmem test, so could be v8.1
changes causing more problems in the rom code resulting in the
failure.
Lowmem = TOOL2.
This tool comes with a calibration app you can use to find the minimum OK
setting for a particular phone - so find the minimum calibration first, then
if you have any errors over and above that setting, they are almost
certainly in your application.
Regards
H
news😛[email protected]...
>[color=green]
[/color]
##[color=green]
[/color]
simply[color=green]
> >would be a bug)
>[color=darkred]
> >> > > charger)
[/color][/color]
name="AppScreenMonitor">Searching[color=green][color=darkred]
[/color][/color]
the[color=green][color=darkred]
> >## Could be as you've said. Certainly SymbianSigned test house will run[/color][/color]
the[color=green]
> >test manually.
>[color=darkred]
[/color][/color]
wrong[color=green][color=darkred]
[/color][/color]
then[color=green][color=darkred]
> >> > > occured.
> >> > > constructl
[/color][/color]
24576[color=green][color=darkred]
[/color][/color]
25600[color=green][color=darkred]
[/color][/color]
26624[color=green][color=darkred]
[/color][/color]
27648[color=green][color=darkred]
[/color][/color]
28672[color=green][color=darkred]
[/color][/color]
29696[color=green][color=darkred]
[/color][/color]
30720[color=green][color=darkred]
[/color][/color]
31744[color=green][color=darkred]
[/color][/color]
> >> > > following errors:
[/color][/color]
33792[color=green][color=darkred]
[/color][/color]
34816[color=green][color=darkred]
[/color][/color]
35840[color=green][color=darkred]
[/color][/color]
load[color=green][color=darkred]
> >> > > of these errors:
[/color][/color]
152576[color=green][color=darkred]
[/color][/color]
153600[color=green][color=darkred]
[/color][/color]
leave[color=green][color=darkred]
[/color][/color]
I[color=green][color=darkred]
> >## What happens on low mem if you run using TOOL2? This tool starts[/color][/color]
testing[color=green]
[/color]
application[color=green]
> >framework.
> failure.
> http://www.Oval-Racer.com[/color]
